View Full Version : konica 7165 grainy copies and spilling dv
digicor
05-11-2011, 08:46 PM
I have a 7165 spilling dv and getting grainy copies, 38 k on the dv, new drum and blade...
hmmm... i had to increase the HV charge to 255 to get it to stop,cleared it right up. what would cause this to be so abnormal? possible hv board on the blink? confused for now but its working.:confused:
CraigW
05-11-2011, 10:09 PM
Check the PCL lamps operation.
Luther
05-12-2011, 01:18 PM
Also restring the charge and replace the grid
pepper38_cnd
05-13-2011, 12:44 PM
Look at the mylars on the ends of the T/S Corona assembly. If they are worn or torn the T/S comes too close to the drum discharging it and causing it to pull dev. If they are damaged you should replace the T/S Corona.
JustManuals
05-13-2011, 07:50 PM
Just Manuals | The Internet's largest selection of manuals | Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
Chek your dip-sw setting at dip-sw 27,make sure the bit 0,1,3,5,6,7 set to "1". Also dip-sw 23 bit 2 & 3 set to "1". i think you use non original toner
