View Full Version : Miscellaneous Develop Ineo +253
CrapAimer
05-12-2011, 11:27 AM
Hi All
Want to replace fuser reset fuse ordered one up, could someone give me a pointer to were the hell it is .
Many Thanks
EarthKmTech
05-12-2011, 11:46 AM
its a c253 for the rest of the world ;)
you dont even have to remove the fuser unit to rest the life counter.
the fuse, if it still has tails on it, can be inserted into the long flat multipin connector at the front of the machine under the black plastic cover for the fuser connections.
however, i dont recall which pins they are.
the fuse itself is bundled into a cable tie from memory on that multipin cable inside the fusing unit and that will enable you to determin which pins to use.
