View Full Version : konica1216
cliffhangers
05-14-2011, 05:25 PM
Hi,I am haven problem with this konica1216 it is displaying error code 09.please i need your help.THANKS IN ADVANCE.
mrwho
05-14-2011, 05:32 PM
Check this:
DESCRIPTION: F09 at power up.
CAUSE: Current flow to frame ground is detected. This may be caused by an external power surge or internal arcing.
SOLUTION: To reset the code, perform the following:
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON while simultaneously pressing the 2 and 5 keys), P49 to 0.
3. Power the copier OFF/ON to exit the 25 mode.
4. When ready to copy is indicated, check for normal operation.
5. If the code reappears, replace the main CB (p/n 25LE-9320) or the high voltage unit (p/n 35EA84010).
JustManuals
05-14-2011, 08:40 PM
Just Manuals | The Internet's largest selection of manuals | Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
