View Full Version : ineo+451/bizhub c451
Zeldaman
05-18-2011, 05:26 PM
Hi there!
I´ve got a lil´problem. Changing IU´s C,M,Y ;Transferroller & Transferunit. After switching on all is good, but the counter of the Transferbelt-unit will not reset. The hotline say´s maybe the fuse not blowing up! I´ve often change this unit and never had problem with the counter-reset. Has anybody a solution for this problem?i´m not in the mood (nor my boss) to change it again. Thank´s a lot for any ideas.
Greetings...
Zeldaman
05-19-2011, 11:17 AM
Hi there!
I´ve found the fuse at the back of the unit: 250V 80mA. Don´t take a stronger one cause there´s imidiatly a malfuntion-code c-2152.
Greetings...
EarthKmTech
05-19-2011, 12:53 PM
if the fuse meters out ok, and the wiring or contacts arent at fault you may have a faulty printer control board.
Zeldaman
05-19-2011, 01:03 PM
Hi there!
I hope not, but i´l check it out.Thanks.
Greetings...
Zeldaman
05-19-2011, 07:21 PM
Hi there!
Problem solved. Put in a new fuse, turn the machine on, counter is reseted.
Greetings...
