View Full Version : Error Code C250 error c2152
danrobin54
05-23-2011, 03:35 PM
Can this error C2152 be cleared on the C250? or is sensor dirty? How would i clear if it can. Thanks
JustManuals
05-23-2011, 05:09 PM
Just Manuals | The Internet's largest selection of manuals | Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
fixthecopier
05-23-2011, 10:55 PM
Transfer belt troubles I think. If you are not a tech, call one.
danrobin54
05-24-2011, 06:49 PM
Thanks. I am a tech. Sharp mostly. But have work on Konica Minoltas for about 4 years. just not these models. I did get the service manual. So I will read up on it.
RRodgers
05-24-2011, 08:02 PM
On the newer Kinica boxes go into tech mode, then counters, then service call counter. The box will tell you what the code means. If its not listed in there, then its an accessory problem ( ie finisher, lcc, paper banks)
HtH
remati
05-24-2011, 10:11 PM
with this code ,you could have,
the easy way...clean the sensor or change the transfer belt...
...or ...
you could have the very difficult way...change the sensor and the actuactor...and for this you need some hours ....see tha manual how to do that ...
