View Full Version : jamming
luis8832
05-26-2011, 03:33 PM
Working on a new cs-300i with a df-670(b) finisher. problem i am experiencing when they print to the finisher the first pages comes out ok and the second page crashes into the exit gate causing it to jam in the fuser. It also happens when it copies. Any suggestions. I am going back there today to set up one more pc to scan. I will do further testing and update the thread.:cool:
aabarnes1
05-26-2011, 07:05 PM
is this the black/dark grey 760-B finisher, if so check the entrance sensor under the large door on top of the finisher.
Kidaver
05-26-2011, 07:14 PM
tell them to not lean on the finisher lol
JustManuals
05-26-2011, 09:16 PM
Just Manuals | The Internet's largest selection of manuals | Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
luis8832
05-26-2011, 11:07 PM
went back today and now the unit jams on the duplex. It makes 2 to 3 doubled sided copies then it stays at printing. When you open the side door the paper is on the flag, then the unit says jam. Jam00
Kidaver
05-27-2011, 02:08 PM
Jam00 usually means there is a sensor on when the machine is powered on....but if you are getting a few prints and then this jam00 sounds odd....tho you might swap out sensors in the duplex area to see if maybe one of them is faulty...
luis8832
06-03-2011, 04:15 PM
just replaced the sensor in the duplex section. No success it makes three doubled sided prints then it stays on printing and goes no where. When i open the side door i it gives me jam00. If i don't open the door the units stays in printing mode and wont do anything. Also the unit is experiencing a c7300 code, 10 times. I have never had a brand new unit with this many issues. Any suggestions?
blackcat4866
06-04-2011, 04:07 AM
After you installed the finisher & other accessories did you upgrade the firmware? Machines and accessories frequently have various levels of firmware, until you flash the machine. To me, it sounds like you might have incompatible levels of firmware. =^..^=
jummamaster
06-04-2011, 07:32 PM
check if all sensors are working properly. you can do it in service input check mode.
