Installing chip on Konica?Minolta C452 color IU
  • Tata
    • May 2008
    • 42
    [Misc] Installing chip on Konica?Minolta C452 color IU
    I have a C452 that is calling for IU (color) to be replaced. I bought the replacement chips but could not find were to install it. Any help I would appreciate. Thanks
  • acusso1234
    Tecnico
    • Dec 2008
    • 250
    If I'm not wrong it must be in the same position of the chip on the C 350/351/450 IU Black...under the front cover of the IU.
    ... In the minute that you're thinking of giving up, think about why you lasted so long ...
    • Tata
      • May 2008
      • 42
      Thanks, but I already tried that. I wanted to know if is true that the first IU on the machine does not have a chip, but the ones replaced do. Does Konica wants to make sure you buy at least one IU before you can chip them?
      • acusso1234
        Tecnico
        • Dec 2008
        • 250
        ......mmmhhh..
        Yes!
        • Tata
          • May 2008
          • 42
          Originally posted by acusso1234
          ......mmmhhh..
          Yes!
          Thanks. Just what I thought!
          • Gaffers01
            • May 2011
            • 315
            I presume this is the first time you have tried to change the Imaging units as when you buy the machine from the factory the IU's on the new machines don't have chips on them.
            When you order a new set up they will have re-placeable chips on them.
            This is a way of KM forcing people to by a second set of iu.
            • Tata
              • May 2008
              • 42
              Actually, is the first time that I tried to replace a chip on a C452. Up to now, all the other ones could be replaced because they came with chips. Thanks
              • The-Peanut
                • Aug 2006
                • 192
                just a thought
                what if the old original IU (that came with the machine from new with no chip fitted) was replaced with a brand new one, then removed and the old one refitted,
                then the new one gets a new chip fitted and put back on the shelf?
                • Tata
                  • May 2008
                  • 42
                  That's brilliant!! It's worth a try. Thanks.
                  • Chip Resets SA
                    • Sep 2010
                    • 46
                    Re: Installing chip on Konica?Minolta C452 color IU
                    Very clever idea, will let my clients know and see what the outcome is, thanks
                    • pbbsinc
                      • Nov 2005
                      • 90
                      I have this very same situation. Did anyone ever find out if the factory installed IUs can be reset by installing a chip in them?
                      • Darren King
                        copiertech
                        • 652
                        Install the new special firmware and set the softswitches and you will never have to rechip another IU again. It also stops the end of life messages for the fuser and transfer belt. It works on colour machines from C353 series, C280 series and C452 series, and BH223 b & w series
                        • The-Peanut
                          • Aug 2006
                          • 192
                          I like the sound of that
                          Where can this firmware be found?
                          • Darren King
                            copiertech
                            • 652
                            You have to be authorized KonMin service. It is on their support website
                            • The-Peanut
                              • Aug 2006
                              • 192
                              That's cool, I am, I'll take a look when I get to the chance but I'm surprised that KM would release a firmware that would loose them revenue
