View Full Version : minolta 1054
zoraldinho
06-01-2011, 06:57 AM
Hello
I change the drum and now i have very light copies.No changes if i playing with
F3 or F5 settings.What the hell can be wrong.I'm not familiar with Minolta.
Can anyone give me a tip.
Thanks.
hi friend zoran ...maybe your assembly toner unity contain only developer ...but try seeing the toner cartridge if you started copy he moved on or no ?...maybe it have problems at the rénime of motor toner ..her cause it is blocked ...we have not making the toner ...try on ..and l can assisted with you ..this model is very useful in my city ...
Gaffers01
06-01-2011, 09:40 AM
Hi,
I havent worked on this machine for a while but i think you have to run F8 when you replace the drum then F3 and the F5 in that order. If this doesnt work go in to F5 and you can manually adjust to make the copies darker by pressing the up or down key.
at F5 section use up & down button to manual adjust the value then press start button
JustManuals
06-01-2011, 04:19 PM
Send me an email. I'll send you the SM.
Paul
bojans
06-01-2011, 05:27 PM
Long time I didn't work with these models.
Use to have problems with light copies caused with transfer corona assy. Try to find another one and change it. You can also play with lamp settings.
We use to set up everything with these settings:10080
Good luck
zoraldinho
06-01-2011, 07:43 PM
Thanks for the posts.Will be in touch.
