View Full Version : kyocera km 2550 error c0960
javier4065
06-08-2011, 09:05 PM
display says error c0960 .What is the developer board? and what can I do to solve this code?.Thanks.
JustManuals
06-08-2011, 10:34 PM
This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
http://www.justmanuals.com
Paul@justmanuals.com
blackcat4866
06-09-2011, 12:30 AM
It's the little crum chip in the developing unit identifies the unit's serial number, copy count, and compatibility with the engine.
So the chip itself could be bad, the developing unit may be incompatible (did you just change it?), or there may be a wiring problem between the chip and the main PWB. =^..^=
javier4065
06-09-2011, 03:45 AM
thanks for your answer,but there are two chips, one of them is near to battery and a memory and another is on board in the middle of the machine with several conectors. what is the developed board.thanks.
blackcat4866
06-09-2011, 04:11 PM
It's the only one on the developing unit. =^..^=
jummamaster
06-09-2011, 07:04 PM
After changing the board or developing unit, make sure that you insert the developing unit connector correctly on the engine PCB. There are two similar terminals on the engine pcb, if it is inserted in the wrong terminal, new developing unit board will also burn.
