View Full Version : Miscellaneous what is supported konica minolta software for C450 scaning?
akbareshghi
06-15-2011, 04:43 AM
please introduce one software that fully-compatible with C450
ie for scanning with 2035 Aficio ricoh introduced Desktopbinder
what soft konica introduce for Bizhub C450?
thank you for attempt
Socialist
06-16-2011, 09:47 PM
It's PageScope Workware - document management software that converts paper and
electronic documents created in different applications into PDF format files, and enables
integrated management of these files.
akbareshghi
06-17-2011, 07:29 AM
thank for reply but your suggestion is for windows 2000
i find
PageScope BoxOperator v3.2.06101
PageScope DirectPrint v1.14
PageScope DataAdministrator v4.113
which software for scaning picture full compatible with C450?
akbareshghi
06-17-2011, 07:30 AM
i find
BIG PAPA
06-17-2011, 10:08 PM
What problem are you having? It can scan without any other software. Email, FTP, and SMB. Into several file formats PDF being most common. What do you need to do?
RRodgers
06-18-2011, 06:33 AM
You can twain it, you can email it, you can box it, you can SMB it, you can even remote scan 5 it (if you have a Fiery)
We need more info.
kronical
06-20-2011, 10:39 PM
ANY scanning software will work just fine with this machine as long as it is TWAIN compatible software, and you have to install the TWAIN driver for the device on your system.
HOWEVER - TWAIN is quickly becoming a thing of the past, as more and more devices are fully network scanner capable.
I suggest using SMB or Email scanning over the network, no extra software, more control.
