View Full Version : Bizhub 25 Admin Password - Web Connection
Mooseface2r
06-16-2011, 10:25 AM
Hi does anyone know the above. this is the first one of the Bizhub 25 iv seen. Iv tried all the usual:
Password
00000000
88888888
I know to log in on the copier is 000000 but cant figure it out on the web connection.
Any help much apreciated
Cheers
Zeldaman
06-16-2011, 10:56 AM
Hi there!
Itīs 12345678
Greetings...
Mooseface2r
06-16-2011, 11:29 AM
Hi Thanks for the replay, Iv tried this one too with no luck.
This is the machine im talking about if there is any confusion http://www.konicaminolta.eu/business-solutions/products/copier-print-systems/multifunctional-systems-colour/bizhub-c25/key-features.html
cheers
Mooseface2r
06-16-2011, 12:19 PM
Thanks for the reply, this was the first one i tried, doesnt seem to work for me, just to clear up any confusion its the small a4 colour im on about.
Cheers
bizhub1
06-16-2011, 12:57 PM
The default password is administrator
Gaffers01
06-16-2011, 02:11 PM
I think its 92729272.
seantydingco
07-29-2011, 02:43 AM
I am also having the same issue but with a BizHub C20.
I have tried:
1234568
0000000
92729272
Password
password
administrator
Adminstrator
With no luck. I mostly deal with Canons, Ricoh, Samsung, and HP.
Can someone point me to the documentation on how to reset a web connection password to default?
I appreciate the help guys. :)
Sean
RRodgers
07-29-2011, 04:27 AM
Try 123456. That's what it was for the C35.
seantydingco
07-29-2011, 08:34 AM
Thanks but still no Joy....:(
barratec
07-29-2011, 10:05 AM
what about : "sysadm" or "sysadmin" ?
delboy10
07-29-2011, 02:20 PM
Unless someone had tried to change the PW. Info from KM:
Subject:
What are the passwords used to login to PageScope Web Connection (PSWC)?
Description:
What are the PageScope Web Connection passwords?
Solution:
Administrator password = "administrator" (default)
Service password = "KMBC25" (note uppercase)
You can try to log in with service pw, and then reset the key op pw.
cheers
remati
07-29-2011, 09:08 PM
the password is administrator
Password
00000000
88888888
Cheers
Steven Barry
09-18-2013, 10:26 PM
The Admin password for a Konica C35 is 12345678
I'm in front of one right now and that works.
wseyller
09-19-2013, 02:56 AM
Irrelevant totally different device.
To access on control it is 000000.
In embedded web page it is: administrator
Edit: just realized this thread is over 2 years old.
Sent from my Galaxy Nexus using Tapatalk 2
Marlene Miller
10-28-2015, 03:13 PM
Password
00000000
88888888
Cheers
By default the 25e's are not set with any passwords. On the MFP Menu screen go to [settings] then [Management] the [Admin Password] then enter the password of your choosing and press [Enter].
Marlene Miller
10-28-2015, 03:23 PM
By default there is no set password for Administrator, you create one by going to the MFP panel and press [settings] then [Management] then [Admin Password] then create a password of your choosing and then [ENTER] Enter password again and then [ENTER].
Computerspacelv
02-04-2017, 10:20 PM
Hi Everyone,
If you forgot your password, simply turn of the printer, turn it back on and follow:
1- Turn Off the printer
2- Turn it back on
3- Click on setting
4- type *24
5- You get 2 menu to initilize and other one which i fogot, simply press both and follow the screen, with this you reseting the password.
you can do a factory reset by going to setting > management.
Best.
peter42
02-05-2017, 08:28 PM
Dont forget, after 3 choices of login, you have to restart the mfp.
If you enter correct password after the 3th one , nothings happens, no failure meassage appears and you have no access, until restart.
