View Full Version : Miscellaneous Bizhub 283 IU life
This machine only can non-stop sign drum life time. Can we set off the sign like bishub 350 ? :confused:
SmellsHot
06-17-2011, 01:06 PM
in service, system 2, turn of consumable reminder.
kingarthur
06-17-2011, 04:59 PM
correct me if i'm wrong....but if you do this...wont it also stop the low toner warning from displaying
SmellsHot
06-17-2011, 08:40 PM
You are correct. low toner message yes, out of toner message no.
SmellsHot
06-17-2011, 08:45 PM
if you want to leave the low toner message on. Then you will need to changed some software switches.
Switch 51
Drum Bit 4 0x00 is default(on) turn this to 0x10 to turn off
Developer Unit Bit 5 0x00 default turn this to 0x20
Developer Bit 6 0x00 default turn this to 0x40
Fusing Bit 7 0x00 default turn this to 0x80
Our customers (with contracts) always have an extra toner, so we just shut off the reminder.
Switch 51
why i can't found the list of soft switch at manual ? which page ? thanks
SmellsHot
06-19-2011, 02:44 PM
It was a tech bulletin recently from konica
Joshua Julian
06-22-2011, 10:43 PM
you can also try going into service mode and then stop, 0, C
gateway.vly@gmail.com
06-26-2011, 07:53 PM
Plz help to enter service mode km c451
thankx
