View Full Version : Bizhub501 fax forward
KM7155
06-18-2011, 09:46 AM
Hi mates,
can the bizhub501 forward the incoming fax to a destination in one-touch setting?
the bizhub250 can be done, but i can't find the setting in this model, since this model
is using konica firmware instead of minolta firmware like the b250.
hdd is not an option in this case.
emujo
06-20-2011, 01:55 PM
Yes, Admin..FAX setting..TX forward settings...once you turn on fax forward, you should see the address book icon, touch it and select your destination. If you don't see this double check the fax is electronically installed, US marketing..and if still nothing, reload firmware. Emujo
KM7155
06-24-2011, 02:43 AM
thanks for the info, the issue settled.
