View Full Version : 7155 sc29-3
Downunder
08-24-2007, 09:18 AM
Hi, just started fixing these, cleaned the drum, sensors, dev change and drum change set up LD1 etc, and new print board. Am I on the right track.
CMB
08-24-2007, 11:36 AM
did you run the drum preculitarity adjustments? if not. you will be back to change drum and developer again in a few days.
Downunder
08-24-2007, 11:58 AM
Yes I have as per the manual, check and adj voltage for new drum , completed the 1-10 sequence, etc changed sensor board.
ebm
08-24-2007, 07:36 PM
Some suggestions from KMBS.
Light/blank copies & 29-03 - Write unit may be bad.
SC29-03 after Toner concentration dipswitch settings changed - reset dipswitch.
CMB
08-24-2007, 10:57 PM
this is what the service manual says.
f-29-03
control patches are not output while Dmax correction is in progress.
no output from the Dmax sensor.
remedy:
TSCB (toner control sensor board) thats the sensor that looks at the drum in the drum carraige.
or
PRCB (printer control board)
i would try the sensor (TSCB) first.
Downunder
08-30-2007, 10:07 AM
Thanks guys -- printer control board.
