View Full Version : C6000 with cyan magenta lines across
adeyemi
06-22-2011, 05:10 PM
After installing a new C6000, prints and copies are coming out with closely but regularly spaced lines that are either cyan or magenta in color. Please what could be the source of these? Thanks
ExXeroid
06-22-2011, 05:23 PM
Did you follow the install procedures 100%?
Go back to the install procedures and perform every step in the procedure exactly as written.
Your lines will go away.
rangertech
06-23-2011, 07:59 AM
make sure the installation procedure and all step its correct...
ExXeroid
06-28-2011, 02:18 PM
Did following install procedure (Doing the setup steps) fix your problem?
adeyemi
06-28-2011, 09:12 PM
Thanks, it did. I was surprised that the problem was caused because i did not put in phone and fax nos during installation (a step i thought was non-critical to the install process).
