View Full Version : Please help! I messed up the konica 7130. 47 mode
ragermac
06-30-2011, 11:12 AM
Hi all. A 7130 was donated to our organization and I was trying to get the network setup but it was not working. So using the service manual I tried to reset it to factory. By doing so I caused more problems. After I did so in 25 mode, I then reset memory. When I turned it on it said to check L detection. I went to 47 mode to check and it came up with 0005 error.
I checked it in the mamualmand it mentions the TDS sensor. I tried to adjust but now the error is call service F-26-3.
What did I do wrong? Please help.
kingarthur
06-30-2011, 11:57 AM
what you did wrong was to touch it in the first place...they say a little knowledge is a dangerous thing...this proves that theory......what you probably need to do is replace the dev...i would also throw away the service manual & contact a proper tech ....
ragermac
06-30-2011, 12:17 PM
true. But our organization is non-profit so hiring a tech would be a problem, so i was trying to do the best I can.
SmellsHot
06-30-2011, 01:37 PM
Enter 36 mode. HV adjustment, try running L Detect, this will run for a few minutes, and if your lucky your code will go away........for a lil while
ragermac
06-30-2011, 01:46 PM
ok, thanks. so do you think this is a problem that already existed?
ragermac
06-30-2011, 11:20 PM
I got it working. thanks everyone.
