Eugene74
07-01-2011, 11:02 AM
Good day fellows
Got a C552 with 150K copies on. Customer complaint that when they make copies on card the second side is much lighter in density than the first side. its 160 gram paper, made copies as far as thick 4 to see if it made any differance, but no luck. Then adjusting Transfer output fine adjustment on 1st and 2nd transfer, Up the TCR levels, Set Dmax setting higher, adjusted thick paper density ans ended with adjusting monochrome density adjustment. But no luck, some of the settings made quality worse, but not one of them made a slight improvement. So by now I'm with my hands in my hair, and pulling them out slowly but surely.
Would appreciate if anybode could assist me with this "little" problem
Many Thanks
Eugene
Many Thanks
Eugene
