Hypnotoad
07-06-2011, 10:15 PM
On our Bizhub C250 it all of a sudden came up with an error code like C2555 or similar, my memory is fading in old age. The code pointed to low toner density in the magenta toner cartridge.
Anyhow I pulled the magenta toner and the magenta imagining unit out and put them back in, shook the magenta toner, checked the little doors on each and all seemed fine but the error persisted.
Then I removed them again and wiped the little chips on each and wiped the contacts on the copier and viola all is fine again.
Just goes to show even the things you can't see affect these things.
