View Full Version : Miscellaneous scanning and printing problems
bunnthebody
07-09-2011, 02:06 AM
We are working on a Konica Minolta 421. When it is powered on and boots, you can scan two documents to any of the scan to file folders. After two it deletes the scan and gives a lost server connection message. You can power the machine off and on and two more will go. I have done a -t ping on both the servers and machine. The time is always good. Any ideas would be appreciated. roger
TheOwl
07-11-2011, 02:26 AM
Sounds like a firmware upgrade might be needed to address this issue. Try that and let us know if there is still a problem.
aleksander
07-11-2011, 04:51 AM
agree with theOwl, try to rewrite the firmware.
rangi
07-11-2011, 10:36 AM
Try replacing the Hard Drive.
mo0651
07-11-2011, 02:25 PM
If you have a harddrive, try a reformat first.
bunnthebody
07-12-2011, 03:55 AM
This machine does not have a harddrive. thanks
nmfaxman
07-12-2011, 04:00 AM
Install Hard Drive.
As always.................................
