View Full Version : Error Code K drum unit installation error on Bizhub C280
Skipper
07-11-2011, 09:08 PM
Has anyone seen this before?
thanks in advance
acusso1234
07-11-2011, 09:14 PM
It appen when you swap used drums between 2 different printers
Skipper
07-11-2011, 09:19 PM
Customer had message to replace and tech replaced drum unit then updated base firmware and then a code of C2A14 came up. Then installed new special firmware for turning off life counters and replaced with new drum unit. The code went away and this morningwhen machine came out of sleep mode the installation error came up.
pepper38_cnd
07-12-2011, 11:18 AM
Whar version is the new special firmware for turning off life counters?
mitchl
07-12-2011, 06:18 PM
yeah that does sound interesting, I'll jump on the site and see whats what.
emujo
07-12-2011, 06:29 PM
New f/w posted on KM (US at least) site...turns off all I/U's Fuser, and X-fer belt messages. Works on C353, C650, C360, C652, 552, and 463 series. Emujo
Spidula
07-14-2011, 06:14 PM
Not heard of an X-fer belt (joke. Im assuming its a typo). I work for a dealer and we are using C2 on the C280 and C452 series and also on the 223 models. GFF-R6 on the C253 and C451 series.
You can reset belts and fusers on the new colour without f/w.
PeterG
07-15-2011, 05:59 AM
I have had this recently, but firmware wasn't involved. Ended up replacing image unit, mfp board,prcb, nvram, the actual sensor assembly itself & it's associated pcb behind the waste toner. Fault still came back. I think I have it isolated to the harness at the top of the mfp board. I have cut all the zip ties in that area & fanned out the harness. Seems OK at this stage.
pieter laubscher
07-15-2011, 02:19 PM
i have had it in last week on a c220 and only thing that worked was to replace the image unit
MILLER4157
07-19-2011, 06:00 AM
i've had it happen with the wrong drum unit. all of the drum units in the c280 look identical but the black has a different part number of A0XV0RD the colors are A0XV0TD. hope this helps?
PeterG
08-02-2011, 02:03 AM
It seems I spoke too soon!
Have replaced the following
Black image unit.
Small harness & contact pcb that contacts IU
PWB-F Assy
PWB-MFP
PWB-MC.
Cut cable ties & loosen harness around plugs on PWB-MFP
Fault may dissapear for 6or7 weeks but then recurs.
Last 2 times I have been on site, fault has cleared by wiggling harness at MFP board.
I have checked every wire on every connector at MFP. I can not get fault to re-occur at will.
Any clues?
Ianizer
08-02-2011, 03:30 AM
Not heard of an X-fer belt...
"xfer" would be abbreviation for transfer. I use that too on history logs.
-I
MILLER4157
08-02-2011, 04:30 AM
sounds like you are having a wiring issue more than a software issue. you need to check the pin outs and see where the grounding is occurring in the harness. i would check resistance on all of your grounds.
also you may check to see if new release disable mode has been accidentally activated. it is known to cause weird issues with iu's.
PROBABLE CAUSES:
1. The New Release Disable mode has been activated. This mode is used for troubleshooting purposes only and temporarily disables the detection of new drums or developing units.
Open the front door, enter the Service Mode, select [Enhanced Security] then [Engine FW DipSW]. Touch key number 3 to change it from a highlighted state to a non-highlighted state. Close the front door and power cycle the machine. The machine will now detect a new unit has been installed and reset the life counter.
Note: To make sure that gradation reproducibility is guaranteed, perform Initialize + Image Stabilization, Gradation Adjustment and input the previous Dmax density adjustment value (if known) in Service Mode.
2. Soft Switch 59 is not set properly.
Please set Soft Switch 59 to Hex 01.
a. Enter Service mode.
b. Select System 2.
c. Select Soft Switch Setting.
d. Enter 59 for the soft switch number.
e. Select bit assignment and set the rightmost number to 1.
f. Touch Fix.
g. Touch exit.
SBJ179
08-03-2011, 01:56 PM
I recently saw the K drum unit installation error on a Bizhub C452.
there are three thin contacts near the front end of the developer. One of them was bent when the drum was being lowered into position. I straightened the contacts. All is fine.
AjitN
08-03-2011, 04:50 PM
thanks in advance
What is the exact ptoblem?
I thought all the drum units for CMY partaining to C 220 / C280 / C360 is same.
It should not make any difference.
Ajit
AjitN
08-03-2011, 04:54 PM
Ajit
Sorry, my mistake but CMY is identical & K is different, but same for all C220/C280/C360
Ajit
JR2ALTA
02-11-2013, 03:57 PM
Tried drum and firmware, will definetly try DV unit next.
Just bumping this in case anyone can shed new light here.
PeterG
05-06-2013, 02:11 AM
You Bastard! You had to mention it didn't you!! :)
After 2 years mine has come back.
JR2ALTA
05-06-2013, 03:21 AM
I started a ticket with Konica.it was a logic problem fixed by replacing over all control board.
Two years seems odd. Mine was more once a week
