View Full Version : taskalfa ci250
tulipano
07-11-2011, 10:06 PM
salve ho un problema su una taskalfa 250ci, sia nella stampa che nella copia e' molto lenta.le stampe e le copie sono perfette ma ogni volta durante la giornata sta sempre in movimento per diverso tempo anche 1 ora e poi risprende a stampare . non da nessun codice o messaggio di errore.
grazie x l'aiuto
Hi I have a problem on a TASKalfa 250ci, both in print and copy in the 'very lenta.le prints and copies are perfect, but each time during the day is always on the move for some time as 1 hour and then risprende printing. not by any code or error message.
x with the help
spiderman76
07-18-2011, 02:55 PM
Che versione di fw e di driver hai ????:confused:
ignacio.cortez
07-22-2011, 02:12 AM
Try the latest Firmware.
Also, check the color calibration settings, if is set to fast, it will stop and calibrate alot (which will slow you down),
It could be strictly a printing issue that is slowing the copy side as well
- Do all print jobs slow the copier, or only certain kinds (DOC, PDF, XLS, etc etc)
-- If it is only a PDF
--- try changing the Emulation from PCL to KPDL
--- Try connecting your computer directly to it and print, see if it is still slow, if it is faster is a
Network issue
--- Disconnect the copier from the network and run a copy job that previously ran slow and see if runs
faster. chances are it will.
If it is a Network issue, depending on how much IT support your company gives, you can probably check or have them check the network traffic, maybe even install a small Hub between the wall and the copier, it will probably help you.
Prova l'ultimo firmware.
Inoltre, controllare le impostazioni di calibrazione del colore, se è impostato su veloce, si ferma e calibrare un sacco (che ti rallenta),
Potrebbe essere strettamente un problema di stampa che sta rallentando il lato copia e
- Tutti i lavori di stampa lenta la fotocopiatrice, o solo alcuni tipi(DOC, PDF, XLS, etc etc)
- Se è solo un file PDF
--- Provare a cambiare l'emulazione da PCL a KPDL
--- Provare a collegare il computer direttamente ad essa e di stampa, vedere se è ancora lento, se è più veloce è un
rete problema
--- Scollegare la copiatrice dalla rete ed eseguire un lavoro di copia che prima correva lento e vedere se funziona
più veloce. è probabile che lo farà.
Se è un problema di rete, a seconda di quanto supporto IT della vostra azienda dà, probabilmente si può controllare o farcontrollare il traffico di rete, forse anche installare un piccolo hub trail muro e la fotocopiatrice, probabilmente ti aiuterà.
tecnomarco
08-26-2011, 04:06 PM
anche io ho lo stesso problema in una rete di 13 pc con 3 stampanti + la kyocera taskalfa 250ci, e molto lenta anche se deve stampare 50 pagine b/n , circa 40 secondi per cominciare a stampare un solo PDF A3 non pesante , mentre indirizzando la stampa su un altra stampante nel qual caso una hp 2055 pochi secondi e parte :(.... avete dei suggerimenti
ignacio.cortez
08-27-2011, 05:31 PM
Does it take a long time of you print directly from your computer to the copier? Have you tried changing the emmulation from PCL5XL or PCL6 to KPDL, this will probably help you, Also, do you have try connecting a minihub between the wall and the copier, sometimes the ethernet speed might have some issues, with the minihub, you let the minihub do the switching between 10/100, alternatively you can change the network card's speed to 10 Mbps, it will probably help as well. Are the computers printing directly to the IP or are they printing through a Print Queue, if they are, Bypass the Print Queue/ Print Server to see if the speed changes, it does sound to me to be more of an IT issue on the networking side.
Let me know how it turns out
Ci vuole un lungo periodo di stampare direttamente dal computer alla fotocopiatrice? Hai provato a cambiare ilemmulation da PCL5XL o PCL6 a KPDL, questo probabilmente ti aiuterà, inoltre, hai provare il collegamento di un minihub tra il muro e la fotocopiatrice, a volte la velocità ethernet potrebbe avere alcuni problemi con la minihub, si lascia il minihub fare lacommutazione tra 10/100, in alternativa, è possibile modificarela velocità della scheda di rete a 10 Mbps, probabilmente aiuto.Sono i computer di stampa direttamente alla IP o sono stampa attraverso una coda di stampa, se lo sono, bypass della coda di stampa / Server di stampa per vedere se i cambiamenti di velocità, che suona per me ad essere più di un IT questione sulla creazione di reti lato.
Fammi sapere come andrà a finire
Stampa PDF come immagine
I problemi possono verificarsi quando si stampa un file PDF. Ad esempio, un file PDF puòcontenere contenuti danneggiato come immagini o font che Acrobat non è in grado di elaborare durante la stampa. Stampa di un file PDF come immagine ignora che il trattamento con l'invio alla stampante una semplice immagine del documento invece.Questo processo può causare immagini e font di guardare un po 'più ruvida, specialmenteai bordi. Tuttavia, è possibile specificare la risoluzione in punti per pollice (dpi) in base alle proprie esigenze.
1. Assicurarsi che la stampante sia accesa e collegata.
Se necessario, test di stampare un file diverso.
2. Scegliete File> Stampa, quindi fare clic su Avanzate.
3. Selezionare Stampa come immagine.
Fare clic su OK per chiudere la finestra Impostazioni avanzate di dialogo Stampa, quindi fare clic su Stampa.
good luck
