View Full Version : Electrical power supply problem
kamongo
07-15-2011, 05:56 PM
anyone can help me.
i have a km 2560 machine,when i turn it ON it just start to initialize then cut power.if you switch it OFF/On nothing on the display.it just start and turn off immediately.
Please anyone can help me plz.
Jules Winfield
07-15-2011, 06:05 PM
Was any work done to this machine recently? Perhaps a voltage supply wire got pinched and is being shorted to ground.
kamongo
07-15-2011, 06:13 PM
when i use the generator the problem occurs sometimes.when this occurs when i disconnect everything from the power supply and connect again the machine initialize ok.
Jules Winfield
07-15-2011, 06:24 PM
Ok, that explains it. You should always run copiers on their own dedicated circuit to avoid weird power issues. Not only that, but the copier should be connected to a surge suppressor and not just plugged straight into the wall outlet.
blackcat4866
07-16-2011, 12:19 AM
I wouldn't trust a digital copier on a generator. The power is too dirty. I would use some kind of a power conditioner in between the generator & MFP. =^..^=
