FP 7824
  • mr.cooper
    FP 7824
    Can someone please tell me the button sequence to get a few extra copies before a service call. I'm getting the flashing red open-end wrench.
    Thanks, Cooper
  • skumar
    resat pm
    to enter service mode , press these three keys in this sequence, with out leyying untilall3 are held down"user preset" "oriinal size ledger{11*17}","3"
    to exit service mode press tese keys[at the same time ,simutaneously]
    ' user preset','clear/stop.'if you do not use this procedure. the machine will remain in the service mode
    t hen press "5 " "print" using the touch panel enter the code listed on the left, followed by "ok"the panel can be scrolled with the arrows keys then use the number keys to enter the correct digit for the result that you want press"ok"
    pm cycle if set 0, no pm is called for.1 is1,500 copies. 2 is 200 copies-------------5is 15000copies,6 is 20000,7is 30000------------11is 90000,12is 120000
