View Full Version : Miscellaneous Fuser Noise
bookmyer144
07-20-2011, 05:56 PM
Trying to figure out what is causing a clicking/slipping gear sound in a bizhub cf3102. Seems to be related to the gear that tensions the fuser roller.
empiru
07-20-2011, 07:04 PM
Hi! If you open the fuser unit, you will notice a sensor that determines when the pressure roller is "pressed" on the fusing belt and when not. If that sensor is broken, it never stops "pressing" and that causes the gears to slip.
I hope you understand my bad english..change that sensor and I'm 95% sure it will stop making noises.
Ianizer
07-21-2011, 06:34 AM
Sorry. What's bizzie cf3102 N/A model?
-I
Spratt
07-21-2011, 06:42 AM
Ianizer- The machie was known as a Minolta CF3102. Not a bizhub they were around quite a while before the bizhub range.
I beleive Empiru has the right idea a new fuser may be the easier way to go though.
