View Full Version : E068 - 000 on iR 105
Dedy.P
07-22-2011, 08:17 AM
hallo guys, please help, my copier got an error code E068 - 000 :confused:
(don't have the service manual yet)
Thanks in advance
zoraldinho
07-22-2011, 10:43 AM
E068 The high-voltage output has a fault. (separation charging assembly)
A fault (leak) has been detected while the separation charging assembly is
being supplied
with high voltage.
Remove and mount the transfer/separation charging
assembly. Disconnect and then connect
J7233 and J734 of the HV-DC PCB. Disconnect and then
connect J741 and J742 of the
HV-AC PCB. Replace the HV-AC PCB. Replace the transfer/
separation charging assembly.
Replace the pre-transfer charging assembly.
