Orion_joel
09-09-2007, 07:35 AM
Hi All,
I am new to the site, and have a questions i am hoping you may be able to help with. I have been selling Printers, Faxes, and MFP for quite some time now, but mostly for small business with low volume's so spec's have not really been much of an issue in terms that most machine do more then the client needs.
Well i am sort of stepping up to my first client that really needs a machine that does high volume faxing primarily and some copying secondly. The machine they initially wanted was a Canon iR2200 which the original supplier they approached claimed to be able to get but as yet has not delivered (i also believe this is a discontinued model if i am not wrong), in addition to this the room they are planning to place this machine is to small to really fit a full copier.
Basically what they need is a fax that can handle upto 1000 faxes of 2 to 12 pages per week and copying up to maybe 1500 - 3000 pages a week. I have through along the lines of two possible solutions to offer them, but really need some help with if the machines i am planning to offer can technically cope with the sort of through put i have just mentioned.
Option 1 - A Single Unit that includes copy and fax functions such as the Lexmark X642e or X646e, or a similar model in HP. (any model recommendations are welcome)
Option 2 - 3 Standalone units 2 X Standalone Fax either Brother FAX-8360P or Panasonic UF-6100 plus 1 X Laser MFP for their copying needs.
I believe that both options do have their benefits, but i am really not sure if either option can copy with the volumes i have mentioned or if a higher model is maybe required.
I really appreciate any help that can be offered here.
kind Regards
Joel Brown
kind Regards
Joel Brown
