SMB scanning to AppleMac OS 10.7
  • ITMOSTLY
    • Oct 2009
    • 11
    [Error Code] SMB scanning to AppleMac OS 10.7
    I have a customer that recently upgraded their Mac to 10.7 (Lion) and now their SMB scanning that worked with 10.6 does not work. I have checked the all settings and turned off her firewall and still receive error code EB09C6, on her Konica Minolta bizhub 222, which is pretty much just a catch all for not connecting. Comments from anybody would be much appreciated!
  • delboy10
    • Jun 2010
    • 43
    Re: SMB scanning to AppleMac OS 10.7
    May be related or may be not...? but there are some issues with the last update osx 10.6.8 Mac OS X 10.6.8 Supplemental Update. I would double check the user name and pw in the machine address book to see if they are match (Machine and mac), also check the destination folder.
    • chrissieboy2001
      • Jul 2009
      • 2
      [QUOTE=ITMOSTLY;237243]I have a customer that recently upgraded their Mac to 10.7 (Lion) and now their SMB scanning that worked with 10.6 does not work. I have checked the all settings and turned off her firewall and still receive error code EB09C6, on her Konica Minolta bizhub 222, which is pretty much just a catch all for not connecting. Comments from anybody would be much appreciated![/QUOTE
      Yep same here , Apple now use their own SAMBA smb client which is different from the one shipped with Snow Leopard.
      If i try to connect to the Lion Mac from a SL Mac using smb it fails with a user name / password issue even though i know its correct.
      Sorry no solution yet (maybe 10.7.1 update ?) but it's not the copier at fault ,
      Regards
      Chris Forrest
      • ITMOSTLY
        • Oct 2009
        • 11
        [QUOTE=chrissieboy2001;238287]
        Regards
        Chris Forrest
        Thanks much for your response.
        • JSC
          Gimp
          • Dec 2006
          • 618
          The gene pool could use a little chlorine.
          • dellis
            Try upgrading to special firmware to solve smb scanning problem. Konica Minolta has released special firmware for most models to address this issue.
            • medallo
              • Dec 2008
              • 21
              I have it via ftp? no firmware update.
              • habik
                • 2013
                Can someone cofirm whether this is the way enable FTP on Lion. As I don't have mac myself and would like to know if it works.
                Thanks.
                1. Open a terminal window.
                2. Type in the following command:
                sudo -s launchctl load -w /System/Library/LaunchDaemons/ftp.plist
                3. To turn it off, type in the following command:
                sudo -s launchctl unload -w /System/Library/LaunchDaemons/ftp.plist
                Firmwares HERE
                • habik
                  • 2013
                  Thanks.
                  Also Has what do you think of this? Seems like a handy tool. Clever 16-years old from Norway
                  Fredrik Wiker - Developer Website
                  Firmwares HERE
                  • TheOwl
                    • Nov 2008
                    • 1732
                    Can't remember exactly if this machine does or not, but most newer Konica Minolta machines support WebDAV which is built in to 10.7.
                    SMB is busted, FTP isn't included... What else is this Lion hiding from us?
                    • medallo
                      • Dec 2008
                      • 21
                      if it works: On.
                      sudo-s-w launchctl load / System / Library / LaunchDaemons / ftp.plist
                      off:sudo -s launchctl unload -w /System/Library/LaunchDaemons/ftp.plist
                      Fredrik Wiker - Developer Website:
                      No need to install anything.
