View Full Version : c351. c2152 error
mrfuser
08-04-2011, 01:32 AM
C351. C2152 errorThis error won't clear. Swapped belt, still have error. Tried open close door, power down, still won't.clear. any ideas?ThanksKelly
JustManuals
08-04-2011, 02:37 AM
This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
http://www.justmanuals.com
Paul@justmanuals.com
Ianizer
08-04-2011, 04:56 AM
Perform Trouble Reset.
You know- The power on while doing the thing with the thing?
Touch the thing, see deal, do it again. Poof! Worky-worky.
That, or you left some tape on the Xfer belt.
In which case you need to do the thing with the deal anyway.
HTH
-I
HTH
-I
Yeah, what he said.
rprem
08-05-2011, 09:06 AM
hi
have u checked the sensor on the right side of the transfer belt it must be problem,or otherwise install transfer belt and dont put both the screw just put one screw on the right side and close the door and check it
mrfuser
08-08-2011, 06:20 PM
Sensor on rear wall of copier where the transfer belt slides into was completely coated with toner. Cleaned it off and works fine.
Thanks all!
Kelly
1FRY1
08-09-2011, 01:00 PM
Just deleted it as I see youv'e fixed it
Ianizer
08-10-2011, 07:29 AM
Thanks all!
Kelly
Another stone-cold frikkin copier guru saves the day!
You RAWK, Mr. What a maniac.
High-fives and Rockstars all around.
Dontcha just love it when you're right?:o
-I
