View Full Version : TASKalfa 400ci Finisher JAM 00
MFPTech
08-05-2011, 03:21 PM
TASKalfa 400ci Finisher JAM 00 at start up, no paper in finisher, checked / swapped sensors, replaced Finisher Board - no change. It's one of those small Finishers.
Anyone had this problem before please?
Thanks in advance!
Do you get the error without the finisher?
There is a QA for this problem see if this can help good look!!!
blackcat4866
08-06-2011, 02:57 AM
Thanks for sharing marc. =^..^=
Venom
08-06-2011, 01:23 PM
That is only for the B/W machines, we cut a piece of reg roller cleaning brush and stick on the door post that pushes on the bypass transport unit. I suspect one of the door switches isn"t making good contact
You right, Venom excuse my mistake:o
MFPTech
08-06-2011, 06:12 PM
The machine works fine without the finisher.
Can you check simulation 31 and 241 to see witch sensor is faulty try main firmware update Pack and the option Pack.
