View Full Version : konica minolta bishub c550 CE password reset...help
Darius
08-09-2011, 07:27 PM
i recently change ibt belt and transfer roller unit and i still have a problem with transfer roller unit,the mesage won't go off.
I understand that in the service mode is the counter for transfer roll and need to be reset............i tryed UTILITY/COUNTER DETAILS stop 0 0 stop 0 1 and in service mode ask for a password and i don't know the password (00000000,12345678,92729272 is not working)
Can you help me to reset the CE password?
Thank you
minimerlin
08-09-2011, 09:14 PM
Thank youAsk the tech who changed the password what it is! It must have been changed if the ones you tried do not work.
JustManuals
08-09-2011, 10:18 PM
This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
Darius
08-10-2011, 09:52 AM
Not help, the tech is dead :(
RRodgers
08-10-2011, 03:40 PM
It's in the manual.
Ianizer
08-11-2011, 01:26 AM
It's in the manual.
I'm afraid I'll be watching this thread with interest.
92729272 should be the default password if it's enabled.
If the password is lost or forgotten, it's a tech support call.
-I
minimerlin
08-11-2011, 07:54 PM
Not help, the tech is dead :(Sorry to hear that! But you still have a problem as somebody must have changed the password....only way to fix it now is a KM tech support call!
EarthKmTech
08-12-2011, 11:37 PM
certain machines have built in bugs that allow you to go into service mode bypassing the ce password prompt - at which point you can go into security mode and disable the CE password.
IE, on a c352 once i got straight in to service mode via trouble reset after a fuser error code with the front door open. It may of been a freak occurance or it may be a secret back door sequence of events ;) none the less it allowed me to disable the unknown password prompt. This is not the only machine ive worked on that bypassed the CE prompt involving a bizarre combination of events. I suspect theyre probably bugs ;)
When all else fails one can do an nvram initialize but youll loose everything and the machine will need to be setup again from scratch.
dellt
06-14-2013, 08:36 AM
CE password , is registered in nvram board so you can try Nvram reset procedure maybe it works
