View Full Version : port 9100 on c360
big jase
08-17-2011, 01:57 AM
has any one any experance of setting up the port 9100 to print to the c360. i have never printed via this but have a new customer needing this function:confused:
MILLER4157
08-17-2011, 07:12 AM
To set up port 9100 you have to enable it from the administrator mode of PageScope Web Connection, select Network---TCP/IP Setting---TCP/IP Setting. Enable ldp from here and then specify the raw port (port9100).
once this is done you can specify the ip and port on driver side
i have attached the op manuals for network and print op
11335
11334
