View Full Version : Miscellaneous FS-C2126 MFP
sOUner
08-17-2011, 04:52 PM
Showing "toner is running out (M)", even after replacing (M)toner. There is no excess (M)toner in waste container. Also happening on FS-C5100 Series printer.
JustManuals
08-17-2011, 07:59 PM
This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
I've seen this issue on a FSC2126 and C5150DN printer as well. KMA issued a tech bulletin that clarified the issue. Basically, the toner cartridge drive gears aren't "latched" and you have to rotate the cartridge gear back into a latched position. Re-install the cartridge and it should work.
blackcat4866
09-04-2011, 01:10 AM
Now that you mention it, on the 5100 series I've noticed that the cartridge linkage does not home exactly to the specific position required for a good mechanical connection. The drive seems to home to a position ~15 degrees beyond home. I have educated my customers to turn the coupler on the cartridge ~15 degrees, and it will engage. =^..^=
