ineo+6501
08-18-2011, 01:04 PM
Hi guys
I have a 211 which hangs upon sending a fax via the ADF. The sheet goes half way into the ADF and then stops, no jam indication or error code, it just hangs with "now scanning" in the LCD.
ADF works perfectly in copy mode and scan to PC mode, and machine will send a fax from the glass no problem.
The problem is intermittent with no common reason between use
Any ideas?
Cheers
Any ideas?
Cheers
