View Full Version : Bizhub C250---Error code c-5102 and panel shows copier warming up
Copier dr
08-18-2011, 02:39 PM
My Bizhub C-250 shows error code c-5102. Ive reset it then shows now warming up.
Please help?
JSC
08-18-2011, 03:25 PM
Very common fault with this machine you need to change the motor (m1)
C5102: Main Motor's failure to turn
JustManuals
08-18-2011, 07:40 PM
This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
MILLER4157
08-19-2011, 06:36 AM
easiest way to troubleshoot this issue is to take the back panel off. the main motor and pc motor are the same. both are located at the bottom left. both should spin up when you turn on the copier and it goes through initialization. your pc motor (one on the right) will spin up first. swap the motors and see if the main motor (one on the left) spins up during initialization. if it does not replace your mfp board. this is a common issue where the lead on the board to the main motor blows out. make sure IF YOU REPLACE THE MFP BOARD SWAPP THE EEPROM ON THE BOARD OR YOU WILL GET A CODE.
mfp p/n:4040 0101 0E
main motor p/n: 9314 2400 31
micmouse10
10-07-2013, 09:51 PM
Can you go into a little more detail on this. We are having the same error code and we have the manual but it seems really confusing. I have attached a picture of the back of our machine. Can you tell me where abouts the main 22393motor is??
JSC
10-07-2013, 10:12 PM
You need to take the cage off that contains the main pwb , then it's on the left behind a plate.
micmouse10
10-08-2013, 01:59 PM
22397 Am I missing something? I don't see it??
JSC
10-08-2013, 02:15 PM
The whole cage that holds the main board and hard drive has to come off, it looks harder than it is. You can normally remove the screws and most of the connectors then drop the cage to one side with it hanging by a few cables. It will all become clear to you then....I hope
micmouse10
10-08-2013, 02:31 PM
When you say "cage" what are you referring to???
JSC
10-08-2013, 02:51 PM
The cage is what the main board and hard drive are held in, to get to the drive section where the motors are you have to remove this first. You will have to take the upper rear cover off the left side cover (as you look at the machine from the back) off, then you need to remove a couple of fans that sit on top of the cage, you will see them when take off the upper cover, remove about a dozen screws round the cage, remove the flat cable from the main board and thread it through the gap on the right so it's not damaged remove a couple of connectors then unhook the cage from the main body of the copier.
i suggest you buy a parts and service manual from Paul who posted earlier on this thread.
micmouse10
10-08-2013, 03:17 PM
ok thanks for the info.... I have a parts manual but it was confusing so I thought it would be easier if someone explained it to me.
One last question- I see part numbers listed above.. Do you think we need both those parts if we are getting the error code 5102- main motor's failure to turn.
Or just the main motor?
And do you have a reliable place to buy it? Has anyone ordered from this place before?
Motors Genuine Drive Motor for Bizhub 362 282 222 and more 9314-2400-31 (http://www.arcservicesco.com/3433/genuine-drive-motor-for-bizhub-362-282-222-and-more-i-9314-2400-31)
micmouse10
10-08-2013, 03:24 PM
Thanks for the info...
One last question- would I need to order both parts that are listed above?
The error shows c5102 Main Motor's failure to turn. Or do I just need main motor p/n: 9314 2400 31?
Does anyone know a good place to get this? I've listed a place below. Anyone bought from them?
Bizhub350
10-22-2013, 10:10 AM
I hope this would help you have a nice day....
22592
JSC
10-22-2013, 07:49 PM
can't remember the the part number, but you just need to order the m1 moter assy.
sorry for the late reply.
