Hello All,
We have an old Minolta Bizhub C350 that's served our small non-profit well over the last several years, that is, until we moved down the street and around the corner last month. Upon the initial move it was working fine until a couple of days ago. There was a mis-feed at the side door and that was removed and I'm not sure whether this jam indicator came on after the first jam was removed or if it was indicated with the other jams because I wasn't here at the time. Anyway, I've checked all the areas the you can check for any paper mis-feeds, bits of paper, etc., especially in the output area and I've found nothing and the jam is still indicated. Any ideas anyone? Since this is our primary copier, any help would be appreciated. Thank you.
