BizHub Pro 1050 EP Paper feed problem - J18-07
  • scotsman60
    • Mar 2011
    • 32
    [Jamming] BizHub Pro 1050 EP Paper feed problem - J18-07
    Hello!!!!
    I'm having a problem with my BizHub PRo 1050 EP.
    When I feed from drawer 4 in the PF, I get a J18-07 jam code.
    From the manual - this code says - "The PF exit sensor (PS99) does not turn ON within a specified period of time after the loop sensor /2 (PS94) turns ON."
    So I replaced the Exit sensor - no change
    If I pre-feed a sheet partially through the feed rollers, this sheet feeds fine but the jam code comes up on the second sheet.
    I relaced all of the paper feed rollers - didn't make any difference.
    I'm thinking one of the PF clutches may be slipping, or maybe the rollers in the vetrical conveyance section might need replaced?
    Any ideas on what I could try first or how I should diagnose this?
    Or is there something else I should be looking at?
    Thanx in advance,
    Doug
