View Full Version : C6000 refuses to print multiple copies of jobs
adeyemi
08-25-2011, 06:03 PM
Hello,
When jobs are sent through certain packages, the machine (C6000) refuses to print multiple copies, e.g 5 sets of a 20 page document. It simply prints the first set and the job seem to hang on the printer. These happens with Microsoft office packages and with PDF files. It works well with CorelDraw files. what could be the problem? Thanks.
blackcat4866
08-25-2011, 06:09 PM
What print language/emulation are you using? Have you tried the other option? =^..^=
adeyemi
08-25-2011, 08:38 PM
I'm using PCL, if that is what you mean. Are you suggesting PostScript driver?
blackcat4866
08-25-2011, 08:50 PM
Actually I was hoping you would say PostScript, so I could say,"Try PCL!"
How about a image memory issue?
Sorry, that's all I had. =^..^=
adeyemi
08-25-2011, 09:06 PM
So what if its an image memory issue...increase the RAM? By the way, it's an internal controller. Thanks
blackcat4866
08-25-2011, 09:09 PM
Upgrade or replace, depending on the amount you already have. =^..^=
adeyemi
08-25-2011, 09:13 PM
Ok thanks, but what baffles me is why CorelDraw works?
RRodgers
08-25-2011, 09:18 PM
Change the number of pages you want to print in the print driver window NOT the print screen (ie hitting file then print opens the print window) you get the print driver screen when you hit properties.
HTH
adeyemi
08-25-2011, 09:34 PM
ok....quite reasonable
kalindd
08-26-2011, 12:22 PM
Which IC you're using?
adeyemi
08-26-2011, 09:39 PM
IC601
adeyemi
08-26-2011, 09:44 PM
IC601
kalindd
08-27-2011, 08:09 AM
As far as I know PCL is not supported yet on Ic-601.
I can't find any pcl drivers on konicaminolta.eu or konicaminolta.us.
