View Full Version : Miscellaneous C280
AlSyed
08-29-2011, 04:34 PM
I got this BizHub C280 Brand New. Set it up and printed out the report which is fine. Made copy from glass and got these fine lines apart about 1/2 inch. Cant figure it why its printing fine but giving these lines when making copies. Followed the setup procedure 2 times but nothing changed. Any help will be appreciated.
Tnx
mo0651
08-29-2011, 07:14 PM
colored lines? Get an updated version of setup. they missed a step and that is why you are having trouble. Including touch screen.
MILLER4157
08-31-2011, 03:54 AM
if it is a new install. make sure that you have run all of the proper calibrations. lines could be produced from not running new drum/ dv life unit detect or running gradation.
i agree with mo0651 you probably skipped something in the setup.
AlSyed
09-01-2011, 03:00 PM
Tnx Guys, Ran the Gradition 3 times in every step. The detection of new DV/Drum is in which manu. Please advise. Sincere Regards to you all.
MILLER4157
09-01-2011, 11:32 PM
new article life is detected by the chips on both the developer and drum units. so you should be good. are you still having lines?
ezzysi
09-06-2011, 05:28 PM
Had exactly the same issue today on a new C220 PDI, thin coloured lines all over page approx 20mm apart.
Re-followed the PDI instructions WORD for WORD and the fault was gone.
Simon
AlSyed
09-10-2011, 08:53 PM
Hello Friends, I am agree that the mistake was not to follow the instructions "WORD TO WORD" and "STEP BY STEP". I was entering time as 12 hour clock as I was coinsidently doing both setups after lunch and entered time as 1:45 whereas it should have been 13:45. Machine is making nice copies.
One more setup is how to increase image density from ADF. When I make copy from Glass its very nice but from ADF its little light.
Again Thanks for all the friends for input and help on ADF issue will be appreciated.
