Bizhub C351 error C-d004
  • Lasman26
    • Mar 2010
    • 8
    [Error Code] Bizhub C351 error C-d004
    New customer called,recieved a Konica Bizhub C351 and it has an error code C-D004. This is a new machine to work on for me.
    We are Toshiba dealers. Any help would be appreciated
  • nightshade
    Chromographic Supremesist
    • 158
    Re: Bizhub C351 error C-d004
    Hard drive error, most likely a damaged ribbon cable.
    • Lasman26
      • Mar 2010
      • 8
      I'll check that out, I assume its in the back of machine? maybe got damaged in moving. It was recently donated to a school that we service. Thnak you
      • nightshade
        • 158
        Yeah, in the back just start taking out the billions of cover screws on the large back plate and you can't miss it.
        • Ianizer
          • Jul 2011
          • 380
          You think?
          Unset the HDD is service mode and reboot. Code should go away.
          Replace HDD and reset as Installed (may need to Version Up).
          ...Then again, the cable might be damaged.
          -I
          My name Peggy.
          You got problem?
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • Lasman26
              • Mar 2010
              • 8
              I would appreciate it if someone might tell me how to get into service mode?
              Is there a reset within that mode?
              What sim or code to test area for trouble? within service mode?
              I would like to check that before removing rear cover things.
              If not,I guess i go back to ACM Technologies and check with my distributor who sells
              these. I just thought someone on here would be knowledgeable about them. and not play the 20 questions game
              Do I have to ask 10 questions to get the answers?
              I'm not interested in buying service manuals.
              • Shadow
                PHD in Sh!t Disturbing
                • Sep 2011
                • 455
                press the utility key and then go into the counter, press the details touch button.
                press the stop key then zero zero then stop then zero then one keys.
                If you need the manuals let me know.
                $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
                • Lasman26
                  • Mar 2010
                  • 8
                  Thank you so much!
                  • Lasman26
                    • Mar 2010
                    • 8
                    I could use the manuals, got into servcie mode,Thank you for your help with that,but couldn't figure out were to go to reset.
                    • nightshade
                      • 158
                      Check your PM box
                      • Ianizer
                        • Jul 2011
                        • 380
                        I'll take door number two, Monty.
                        -I
                        My name Peggy.
                        You got problem?
