cliffhangers
09-05-2011, 12:39 PM
good day,i am haven problem with konica3331,it is displaying error code 36_1 and i input the 25 mode and reset the error code after 1hour it get back to error code 34,35 or 36, i change the hitter unit it start working for two days and start displaying the same error code 34,35 or 36,when i Clair the error code it will start to booth in 30 second stop to display error code 34,35 or 36.i need help.THANKS IN ADVANCE.
mabawser
09-05-2011, 04:41 PM
have you looked at the fuser before resetting the code?1 the codes you are recieving are all to do with warm up heating errors. you could have a worn heat roller/worn or dirty thermistors or anything.
you will need to check the fuser, if my memory serves me right the hot roller coating used to peel off on that type of machine.....then again its been a good few years since ive seen one of those!
