View Full Version : Panasonic Workio DP-1820E Copier
jbreth
09-21-2007, 08:05 AM
Does anyone know where I can download a user manual for this copier? Or maybe you know what this error code is: E03-10.
thanks
suckis
09-21-2007, 08:58 PM
E3-10: High Voltage Power Supply leak (1) - Grid Charge Voltage
1. PS connector disconnected.
2. PS defective.
3. SPC PCB connector disconnected.
4. SPC PCB defective.
5. Corona Wire is abnormal. (Check for: contamination with foreign particles, broken, not installed in the proper position, or loose tension).
suckis
12-01-2007, 10:40 PM
Operating instructions here:
Panasonic UK Download Centre for Manuals, Software and Drivers (http://www.panasonic.co.uk/customer-Support/download-centre.asp)
yakyitz
12-03-2007, 05:30 PM
there is an update for that problem attached please find the bulletin from panasonic
good luck:)
ansuman
12-29-2008, 11:45 AM
Can u plz guide how to get regular update about DP-8016/8020? There is another problem with DP-8016 machine, the developer constantly vanishes resulting the copy quality gets lighter. And if the developer is changed the copy quality gets fine. Can any one give a solution to this? I m tired of changing the Developer.
vlad_robas
03-09-2009, 06:26 PM
i just put back the content of the waste container
derek
03-25-2009, 11:01 AM
try replacing the main charge wire in the drum unit
