View Full Version : Miscellaneous Di3510f COF32 error and COF33 after F8
Neos Eye
09-12-2011, 07:30 AM
I have this second hand Di3510f machine..when i replace the developer i forgot to clear the counter and do F8..COF32c error occur..then i clear the counter and do F8..but COF33 error occur..what will I do?
fixthecopier
09-12-2011, 11:55 AM
Those machines are picky about their drum and developer life need to match. Put a new drum on and try, but do not run the F8 again.
minimerlin
09-12-2011, 08:39 PM
The COF33 code happens because the dev tanks tend to get a warp on the cleaning/mixer shaft so the atdc sensor does not get cleaned. It should clear by shutting down the machine and reboot. Shold be no need to fit drum/dev again as long as the machine has not done too many copies since you forgot to clear the counters.
JustManuals
09-12-2011, 08:48 PM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
Neos Eye
09-13-2011, 09:20 AM
i got it working once..i removed the toner bottle, print black copies until "please add toner" occur..add a new toner bottle..i changed the tds adjustmnet to 135, works fine on few prints,then cof32 error..adjust to 140, few prints, cof32 error..now im on 174..im hoping to get a desired value that a sensor could work well..am i doing right???
