View Full Version : C220 page limit when scanning
jemkey
09-12-2011, 05:09 PM
Hi,
We have a Bizhub C220 which only allows small documents (around 7 pages or so) to be scanned. It has 2GB memory installed and the hard disk installed according to the configuration page.
What can I check to see why its not able to scan larger documents? I've had a search around the forum and most seem to point at the hard disk not being installed but our c220 has one installed.
Thanks for any help!
jemkey
jeroen2005
09-12-2011, 08:29 PM
Hi,
Check the scan settings regarding scan resolution.If on high resolution you will get this problem.And what are you scanning?Text are photo?
jemkey
09-12-2011, 09:28 PM
Hi,
It tends to be text (with written annotations) that is scanned in.
How do I check the settings and can this set globally rather than per job?
thanks
jeroen2005
09-12-2011, 10:02 PM
Hi,
touch Send/Fax then you will see scan settings, you can set scan in colour/black /white.set pdf .
Set the settings you want.Then go to utilities - user settings-and select current settings.
jemkey
09-13-2011, 12:46 PM
Hi,
The resolution is set to 200x200dPi (Fine), type is Text/Photo, and its scanning to PDF.
Just tried a 10 page scan with those settings and no email comes through and there's no error on the scanner. A single page scan came through all ok.
The Job result on the 10 pages scan says "Deleted Due To Error"
Under Communcation List, the detail for the job says result: "NG"
thanks
SmellsHot
09-13-2011, 01:22 PM
More than likely there is a file size cap on your email server. Have your administrator lift or change this!!
emujo
09-13-2011, 02:48 PM
details....when you look at the job history and see deleted due to error, you should see a "details" icon. select it and you will get a error code or message. Post what you see and maybe we can help. Emujo
tech51
09-13-2011, 07:19 PM
Get this a lot with scan to email. Set your your file type (in scan settings) to compact pdf multipage. Should be ok afterwards.
jemkey
09-14-2011, 09:51 AM
When I got to Job History and select the job and press the Details button this is what I get:
Detail
8138
SCAN
Jemkey
SKMBT_C220111091314060
E-mail
10
13/09/2011 14:07
13/09/2011 14:17
I can't see anything to click on next to the results field?
SmellsHot/tech51 - thanks for the suggestions, I'll give those a try!
pepper38_cnd
09-14-2011, 11:12 AM
Using your web browser log into the copier as administrator, go to the email settings and change the maximum file size to "0" Unlimited.
