View Full Version : Plz. Somebody. Anybody. C352 no light from display/op. panel
SKTeK315
09-13-2011, 04:37 AM
What's up all ?
Plz., no light from bulb. Contrast only does just that. Makes LCD ELEMENTS ON SCREEN GET DENSEER, (more visible & fade away when VR turned opposite. If it's not the op-panel then WHAT ???
Gaffers01
09-13-2011, 11:15 AM
I think there is actually a lamp in the display, its the bit under the touch display with (White casing) that needs to be replaced.
SKTeK315
09-13-2011, 02:27 PM
I think there is actually a lamp in the display, its the bit undeMoy the lamp. r the touch display with (White casing) that needs to be replaced.
Not the lamp. Changed 2 then op panel. If not the panel or the bulb nor the ribbon cable, then...?
acusso1234
09-13-2011, 09:13 PM
Check the connection of the silver connector on the right side of the machine. Sometimes give problems.
SKTeK315
09-13-2011, 09:31 PM
Check the connection of the silver connector on the right side of the machine. Sometimes give problems. Seems ok. It's only the display lamp that's effected. Nothing else. Contrast dims & brightens the LCD bits but no light
copytechman
09-13-2011, 09:35 PM
Likely blown icp on scanner board if you can see the screen but it's not backlit. Either repair the icp or replace the scanner board iirc.
Regards!
A.
SKTeK315
09-13-2011, 09:46 PM
Regards!
A.
That's what I thought. Tnx. What's icp ? Is that the board behind & lower of the ccd ?
copytechman
09-13-2011, 11:48 PM
Yeah, hard to describe the icp exactly but if you've had dealings with them before you'll know what to check.
Regards!
A.
JustManuals
09-13-2011, 11:55 PM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
