View Full Version : Bizhub 350, DF 605 jamming
I have a bizhub 350 that is jamming when the paper feeds in. The paper feeds to the triple gray roller and then just stops. It is registering as a transport jam in the counters.
I have replaced the pickup, feed and sep rollers and blown out the feeder to clean sensors etc. It is an intermittant jam, not every copy.
JustManuals
09-13-2011, 05:42 PM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
jeroen2005
09-13-2011, 08:34 PM
Hello,
check/replace the torque limitter on the seperation roller assy,tends to turn heavy.Giving too much friction with jams as result.
Thanks for the replies. The problem was caused by a 1 way bearing on the back side of the triple gray transport roller. I took the back cover off of the df and found the 1 way bearing. I cleaned the 1 way and roughed up the shaft and it fixed the problem.
