vincent64
09-16-2011, 12:22 PM
This is a strange one, have a cust with a KM BH 501, there is a window just behind the unit with a 12v DC power supply and a CB radio on the ledge.
The copier is on a power filter, or was till this, when the cust keys the mic of the CB the power filter "chatters" like a relay cycling on and off rapidly inside and the status light on the filter blink, on several occasions, it shut the mach off till the mike was released.
First thought bad power filter, swapped it out with one I had, same thing, left it off the filter for now.
Mach is networked and has a fax option also.
Now the power supply for the CB is ran from a different outlet then the copier, and the antenna coax is run up the side of the window and out the top of the wall framing arround the window to a small 3 or 4 foot fiberglass whip on the roof of the building.
Any one else seen this ???
