View Full Version : CF5001/8050 Error Code SC33-01
thesius
09-27-2007, 01:06 AM
As far as I know this is a brand new copier with 0 copies. We turn it on and it just comes up with the error code SC33-01. The guy we got it from says that it means that it hasn't been setup yet because its brand new.
Just wondered what that code ment and if anyone knew how I could get this baby going? None of the buttons work, its just stuck at the blank screen with that code.
JustManuals
09-27-2007, 05:45 AM
The guy you got it from......Not a copier tech I assume.
From the service manual
SC33-01: motor abnormality.
HtH
Paul@justmanuals.com
thesius
09-27-2007, 06:06 AM
I went all through that manual too and couldn't find the code. But thanks for pointing that out for me.
Could that code mean that the machine just hasn't been setup yet? Or does it mean there is something seriously wrong and I got ripped off?
JustManuals
09-27-2007, 06:09 AM
You paid with a credit card right?
thesius
09-27-2007, 07:08 AM
Yeah, why is it that bad?
JustManuals
09-27-2007, 07:45 AM
No, it's good. If you paid with a credit card then you have recourse.
thesius
09-27-2007, 12:23 PM
Any idea how I should go about fixing this problem with the motor abnormality?
knightfall
09-27-2007, 12:38 PM
IF this Copier is brand new there should be a service technician dispatched to setup the copier, to install developer, make adjustments and calibrate. Have them come by and setup this equipment copiers also fall into the lemon law.
SC33-01 is a malfunction with the fixing motor M29. If the Machine is Brand New, there are alot of locking plates and screws that need to be removed at setup. Did you buy this machine from an Authorized Dealer/Branch? We unpack, setup, and test all equipment before delivering to a buyer. Even if it is drop shipped, we send a technician out to do setup. Seems odd an Authorized Dealer/Branch would sell you a copier and expect you to set it up.
