View Full Version : c300
wcody76
09-29-2011, 09:42 PM
hey i have a c300 where the customer scans a 30 page document and it divides it into many pdf`s is there a setting that need to switched
Mr Spock
09-29-2011, 11:10 PM
first the machine needs the hard drive installed
then set multipage pdf for the default in the scanner.
wcody76
09-30-2011, 06:23 PM
HDD is installed but i cant locate the multipage function nor can i format the drive when i high lite the physical or logical option. and where in the settings can u set or unset the HDD thanks
mitchl
09-30-2011, 07:00 PM
If I recall you can turn the HDD off and on in System 2 in service mode, make sure its on if someone had it turned off the drive probably took a dump a while back which wouldnt surprise me. If thats the case get the exact numbers off the drive and get one on Ebay.
