View Full Version : Bizhub C6500 have straight line on main scan in leading edge
SCHWARZ
10-04-2011, 04:49 AM
Konica Minolta Bizhub C6500 with Fiery IC-408 has printing result straight line on main scan in leading edge.
Use thin or thick paper have same result.
I was cleaning 2nd transfer, change the fixing unit and transfer belt unit, but have same result.
Anyone can help me please....
Thank you...
Gaffers01
10-07-2011, 11:35 AM
I have exactly the same problem on C5501,
I have recently done a first PM on it. (no line for first 10,000 odd prints)
Yesterday when at the customers I swapped the yellow drum with cyan just to see if problem persisted (I noticed the problem seemed to be with Y) and the line disappeared, feeling very happy with myself I then ran about 10 prints and the line came back:mad:.
I then checked the corona and there was a little white mark on the end block (only just replaced corona's with PM kit) I then cut back the end block and swapped the drum again (magenta drum this time) all seems to be fine know.:D
Hope this helps.
inutelkamo
10-07-2011, 02:01 PM
what paper type and weight?
SCHWARZ
10-10-2011, 03:15 AM
Thank you Gaffers01, i will try your advice
Inutelkamo: art paper 150gsm and 210 gsm
charginga
10-10-2011, 04:00 AM
u can try change drum black to drum yellow,i think this problem on drum unit :)
