View Full Version : Konica7025
cliffhangers
10-04-2011, 04:05 PM
good day.please i am haven problem with konica7025,i have problem with the cleaning blade and change it now the cleaning blade is good it photocopy well bet there is a dag image with little line on the pepper.i need help from any one who have had this problem and solved should kindly help me.THANKS ADVANCE.
BIG PAPA
10-04-2011, 09:10 PM
The cleaning blade has a white spacer on each end, make sure one didnt fall off. Other than that if you can attach a sample could probably narrow it down better.
SmellsHot
10-05-2011, 07:38 PM
You should replace both the drum and cleaning blade together. They wear into one another over time. There might be a small gap between the two of them causing your line.
